Hi All,
Can we add a xamtree silverlight control into xamOutlookbar as we did for winform.
I really appreciate if I can get a sample code to do this case.
Thanks a lot.
Han
Hello itskashif,
there are no available videos for XamOutlookBar and XamDockManager at that point , but you could observe the samples for XamOutlookBar on the following link http://labs.infragistics.com/silverlight/lobsamples/2010.3/. There is also online Documentation, that you could review and get familiar with the features , that XamOutlookBar offers on the following link - http://help.infragistics.com/NetAdvantage/Silverlight/2010.3/CLR4.0/?page=xamOutlookBar.html.
According to XamDockManager, soon there will be samples and Help available for you! Hope that helps!
Nikola.
hi,Can you please tell me that where are the video simples for XamOutlookBar and XamDockmanger for sliverlight?
thanks
hi,Can you please tell me that where is the video tutorial XamOutlookBar for SliverLigh
Thanks a lot for your code.
It could be done like:
<ig:XamOutlookBar HorizontalAlignment="Left">
<ig:OutlookBarGroup>
<ig:XamTree>
<ig:XamTreeItem Header="Level1Node1">
<ig:XamTreeItem Header="Level1Node1Level2Node1"/>
<ig:XamTreeItem Header="Level1Node1Level2Node2"/>
<ig:XamTreeItem Header="Level1Node1Level2Node3"/>
<ig:XamTreeItem Header="Level1Node1Level2Node4"/>
</ig:XamTreeItem>
<ig:XamTreeItem Header="Level1Node2">
<ig:XamTreeItem Header="Level1Node2Level2Node1"/>
<ig:XamTreeItem Header="Level1Node2Level2Node2"/>
<ig:XamTreeItem Header="Level1Node2Level2Node3"/>
<ig:XamTreeItem Header="Level1Node2Level2Node4"/>
<ig:XamTreeItem Header="Level1Node3">
<ig:XamTreeItem Header="Level1Node3Level2Node1"/>
<ig:XamTreeItem Header="Level1Node3Level2Node2"/>
<ig:XamTreeItem Header="Level1Node3Level2Node3"/>
<ig:XamTreeItem Header="Level1Node3Level2Node4"/>
<ig:XamTreeItem Header="Level1Node4">
<ig:XamTreeItem Header="Level1Node4Level2Node1"/>
<ig:XamTreeItem Header="Level1Node4Level2Node2"/>
<ig:XamTreeItem Header="Level1Node4Level2Node3"/>
<ig:XamTreeItem Header="Level1Node4Level2Node4"/>
</ig:XamTree>
</ig:OutlookBarGroup>
</ig:XamOutlookBar>
HTH,
