hi,
I have created template column throught code-behind .In that i custmize the headerTemplate.It contain Image and textbox which placed in stackpanel container.In image we add Tool Tip. It is working with Default style of grid but if i apply custum style to grid then ToolTip is not seen.
Please give the solution....
Thanks in advanced
Thanks SteveZ
It just shouldn't have anything positioned over it. It doesn't have to be last.
-SteveZ
So you mean ContentPresenter should be last at the ControlTemplate......
I believe it's b/c the mouse is being handled on the Dragger rectangle, which mean the tooltip is not getting notified that the mouse is over the contentPresenter.
Thank you Steve... Its Work.
But please can u explane me what was the issue.Because i commented Dragger Rectangle then it was also worked.
I havent worked so much on style,ContentPresenter,ControlTemplate etc. so please explane . . .
