I want to manually calculate Axis' Maximum, Minimum and Unit. The result of calculation looks pretty well to me but I need a possibility to calculate to which values I must round those values. This depends on the Axis height and difference between Max and Min. Is there a way to retrieve an Axis height or actual chart height/width? Not the whole chart control but the chart placeholder where all series are drawn? Or maybe there is another way to set those values?
Thank you
We found that making a sample in our present conditions would take too much time which we as usual don't have :). So we decided to leave it as is and return to it later. Thank you for your efforts.
I am just checking if you had a chance to prepare the sample you mentioned and if this is still actually a n issue for you.
Looking forward to hearing form you.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
More than that. I build chart after web service response which I call in Loaded event. I will try to prepare a sample.
I can suggest you make sure this is executed after the chart Loaded event. If this doesn’t help please send me an isolated sample I can further investigate.
Best regards Petar.
No this didn't help.
I create chart dynamically using Series s = new Series(...) and chart.Series.Add(s). After that I call UpdateLayout and ActualHeight is still 0
