712
Animination of SymbolElement
How could i do DoubleAnimination over SymbolElement's SymbolSize property?
NNT
  • 3255
    Verified Answer
    Hi NNT,
    Unfortunately SymbolElement's SymbolSize isn't a dependency property, but as a workaround you can create a new dependency property that dispatch every change to the map element's one. E.g.:
    In XAML:
     <igMap:XamMap x:Name="xamMap1">
     <igMap:XamMap.Layers>
      <igMap:MapLayer x:Name="MapLayer" IsAutoWorldRect="True" >
       <igMap:MapLayer.Reader>
        <igMap:ShapeFileReader Uri="Shapefiles/usa/usa_st" DataMapping="Name,Caption=STATE_NAME"/>
       </igMap:MapLayer.Reader>
      </igMap:MapLayer>
      <igMap:MapLayer x:Name="symbolLayer">
      </igMap:MapLayer>
     </igMap:XamMap.Layers>
    </igMap:XamMap>
    In Code behind
    1. The SymbolSize Dependency property
    #region SymbolSize
    public double SymbolSize
     get { return (double)GetValue(SymbolSizeProperty); }
     set { SetValue(SymbolSizeProperty, value); }
    public static readonly DependencyProperty SymbolSizeProperty =
     DependencyProperty.Register("SymbolSize", typeof(double), typeof(ButtonSymbol),
     new PropertyMetadata(0.0, OnSymbolSizeChanged));
    private static void OnSymbolSizeChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
     ((ButtonSymbol)d).OnSymbolSizeChanged((double)e.OldValue, (double)e.NewValue);
    private void OnSymbolSizeChanged(double oldValue, double newValue)
     ((SymbolElement) xamMap1.Layers[1].Elements[0]).SymbolSize = newValue;
    #endregion
    2. Create a SymbolElement at specific coordinates
    var element = xamMap1.Layers[0].Elements.FindElement("Name", "Montana").ElementAt(0);
    var origin = new Point(element.WorldRect.X + 0.5 * element.WorldRect.Width, element.WorldRect.Y + 0.5 * element.WorldRect.Height);
    var symbolElement = new SymbolElement { SymbolOrigin = origin, SymbolType = MapSymbolType.Diamond, SymbolSize = 10 };
    xamMap1.Layers[1].Elements.Add(symbolElement);
    Rect worldRect = xamMap1.Layers[1].WorldRect;
    worldRect.Union(symbolElement.WorldRect);
    xamMap1.Layers[1].WorldRect = worldRect;
    3. Animate custom SymbolSize DP that changes to the SymbolElement's SymbolSize:
    var sb = new Storyboard();
    var animation = new DoubleAnimation();
    animation.To = 20;
    animation.Duration = TimeSpan.FromSeconds(2.0);
    animation.RepeatBehavior = RepeatBehavior.Forever;
    Storyboard.SetTarget(animation, this);
    Storyboard.SetTargetProperty(animation, new PropertyPath(SymbolSizeProperty));
    sb.Children.Add(animation);
    sb.Begin();
    Please let me knof if that works for you.
    Ivan Kotev
