STEP1: I have a tree view(TreeView1) inside WARP1
STEP2:I create a new context menu(popup menu) and put it INSIDE the same WARP1.
PROBLEM1: The context menu is not able to detect clicks on it properly.
STEP3: Run the script window.showModalDialog inside the event handler for contextmenu_click
PROBLEM2: It is not opening a new dialog box.
STEP4: ON THE OTHER HAND if i place the context menu OUTSIDE the WARP1, and perform STEP3, it is opening new dialog box.
PLEASE help me solve the above problem. VERY URGENT.
I have found a work around, instead of calling showModalDialog in server side , i am callling it in the client side and it is working,
but the behaviour of Context menu if placed inside warp is still as bad as before.
