335
Loader Message
I have a PivotTable. When reading the data cube, I have posted a message telling the user to wait, as it appears on
http://labs.infragistics.com/silverlightdv/2010.3/ # / Samples / PivotGrid / Basic / DataSourceXMLA
When I expand a row or column, control takes a while to show detail.
Can we now put a ProgressBar or something similar?
When it takes several seconds, the user does not know if you are loading the information if it does not work, ...
  • 2092
    When you expand or collapse a row there's an event for that in the PivotGrid called AxisExpansionChanged. You can use that to start some custom animation and then use the event LayoutLoaded to end the animation.
    I'm not sure about what event to use with columns but I'm sure there's something. Hope this helps even a bit.
