There is a bug in the XamDataTree component.
This can be verified by running the attached application on the latest SR. v. 10.3.20103.2065
Steps to reproduce the error :
1. Drill down from the topmost node until u have 4 levels exposed.
-Person
-Person ( try close this one when you see these 4 levels )
2. Try to close the node on the second level.
--> Crash
As far as we have figured out, the bug is related to the witdh of the XamDataTree component. When the stackpanel that contains the XamDataTree trys to readjust its width based on the XamDataTree width change, the XamDataTree component crashes.
See attached sample.
To run the sample you have to add in InfragisticsSL4.Controls.Menus.XamDataTree.v10.3.dll and the InfragisticsSL4.v10.3.dll.
regards
Øyvind
Hi ojohnsen,
Thank you for reporting this problem.
I have created the support case for it - so you will be notified when it's fixed.
Best Regards,Tania
I realize that I have posted this in the wrong forum section. This should have been posted in the XamDataTree forum section and not here under XamGrid.
Can please one of the moderators move this post to the correct section.
