Hi, I am confronted with the drug drop problem. Please look the sample project. The application crashes according to a constant procedure. 01.The first procedure
The drug is begun, and it clicks the mouse right button on the item that drops. The context menu of the Silverlight standard is displayed. 02.The second procedureThe context menu is shut clicking the title bar of a browser. At this time, the drug icon stops. 03.The Third procedureFinally, System.NullReferenceException is generated if the cursor is hit on this drug icon, and the application crashes.---------------------------------------------------------------------------------It was rejected by the user requirement though I examined the thing that the context menu of the Silverlight standard is not displayed. How can this problem be removed?Please help someone to know good samples , Forum past that looks like.
regards.
[Sample Project]https://es.infragistics.com/community//cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.03.13.57/DragDropTest20110130.zip
Thanks for the detailed explaination and the sample project.
I tried to reproduce the issue, by following your steps, but I couldn't. I used the 10.2 RTM and latest SR builds.
So, here are my steps:
Please, confirm if those steps match what you are performing in your environment and if the dragging indicator disappears when your mouse pointer enters the Silverlight plugin area or it stays until the mouse pointer enters the dragging indicator and then the issue happens?
