304
Binding different datasources to the same XamGrid
I have a XamGrid and a combobox on my xaml page. Based on what value I select in the combobox, WCF returns the data and I set it as the ItemSource of the XamGrid. I am using DataTable to bind the data to the grid.
 public partial class Report: Page
private DataTable resultData;
void proxy_GetDataCompleted(object sender, EventArgs e)
             resultData
= new DataTable(e.Result);
             webGridView
.ItemSource = resultData;
Now everytime I change the selection on the combobox, I do get different datasource from the WCF service (dataset has different columns) and even the data is bound correctly on the UI. For the first time the data is bound, I do see a valid count in webGridView.Columns, however for subsequent databindings, the data seems nicely bound on the grid/UI but the count on webGridView.Columns is 0 and I cannot access each of the columns. Even if I call invalidateData() before binding the new data source, it doesnt work. I apply formatting to the data programaticallly. Now since I cant access the columns when the itemsource has changed, the formatting rules arent applied. How do I fix it?
