445
Formatting Summary Column
I have been trying to format the summary column in the code behind
SumSummaryOperand sum = new SumSummaryOperand();
sum.FormatString = "{0.00}";
col.SummaryColumnSettings.SummaryOperands.Add(sum);
I dont want the summary of the column to appear by default. User should be able to choose to view it depending on his need. But when I click the sigma sign on the column header, I see two 'Sum' options. How do I avoid this issue? I want Sum or Average to have same format as that of the values in the column.
  • 6475
    Suggested Answer
    Basically, you're getting two "Sum" options because you add a second Sum operand to your operands collection.
    So if you want to set the FormatString from code behind you'll need to:
    a) Remove the auto-generated "Sum" operand before adding your newly created one
    b) Apply the format string on the auto-generated "Sum" operand that's already there
    The following snippet applies a format string on all "Sum" and "Average" operands of all top-level columns of the grid:
            private void SetFormatStringOnSummaryOperands()
                var operandsList = from columms in igGrid.Columns.DataColumns
                                   from operands in columms.SummaryColumnSettings.SummaryOperands
                                   where ((operands is SumSummaryOperand) || (operands is AverageSummaryOperand))
                                   select operands;
                foreach (SummaryOperandBase operand in operandsList)
                    operand.FormatString = "{0:0.00}";
    Hope this helps,
