I have a logarithmic scale on a series from 0 to 15000. I found that one of my values is 0.05 and does not show up on the chart. Is there a way I can get small values like that to show up on a chart but still allow for values as large as 15k be displayed without pushing all the "normal" values all the way to the bottom of the chart?
For a little background we are displaying fluid deliveries so the values range quite a bit based on units as type. Trying to utilize the full space of the chart.
I’m going to pass you my sample. I’m able to see the points that are less than zero and the larger values in the chart.
Sorry. I should have given more detail. I am using the NumericYAxis and the IsLogarithmic property is true. I did not set the LogarithmBase value (assumed there is a default) though but I didn't think that would affect the chart as the values approach 0 or am I incorrect?
You mentioned that you have a logarithmic scales series.
Are you setting the NumericYAxis IsLogarithmic property to true? Are you using the LogarithmBase value? You might want to take a look at the xamDataChart sample for Axes > Axis Scale.
