I'm using Infragists WebGrid version 2007 (vol. 2).
I'm updating several text boxes with the content of the selected line of a grid view.
To make this I did the following:
- Registered the event SelectedRowsChange
- Set the row selection mode to Single (SelectTypeRowDefault="Single")
- Disabled any column or cell selection.
After this two strange behavior occur, the argument e (Infragistics.WebUI.UltraWebGrid.SelectedRowsEventArgs e) as the SelectedRows array empty!? (How? I just selected a row)
The other strange behavior (that might justify the first behavior) is that after the event is launch the row is deselected.
To debug this I removed all the code from the callback associated with the SelectedRowsChange. The strange deselecting behavior continues :(
I search for another event that I could use, I found that ActiveRowChange is somewhat similar, so I registered that one, although the e.Row is filled with the active row, the row is deselected...
How can I detect that a row is selected if both events that could give me this information deselect the row I've just selected (even without any code in the callbacks) .
Thanks ahead for the help,
Luís Miguel Pinho
//Add code to handle your event here.
var row=igtbl_getRowById(rowId);
setControls(row); // This call takes the cell values and set the appropriate text boxes
It is client side event and is available in latest version also.
shareeef said:We do this in AfterRowActivateHandler. It works nicely.
Hi Shareef, thanks for your reply, but I don't have that event in my UltraWebGrid, I'm using version 2007, is that event from a newest version of Infragistics?
