I have a regular asp.net radio button on the screen. When the user clicks on either of the 2 radio button options, I need to enable WebMaskEdit control and also change the input type.
I hock up the radio button with a client side function like this:
rdBtnTaxID.Attributes.Add(
"OnClick", "SSNTaxIDChange('" + TaxSSNMask.ClientID + "');");
Here is the client side function
function
SSNTaxIDChange(MaskControlName)
//var maskControl = document.getElementById(MaskControlName);
//alert('found the control');
maskControl.setEnabled =
true;
maskControl.setInputMask =
Based on the alert message that I have, it finds the object, but then does not do anything. Note that all this is inside a user control (ascx)
Nevermind, I was using Methods as properties. This worked.
maskControl.setEnabled(true);
maskControl.setInputMask(
