265
Data binding issue with Pie Chart
I have to switch from Column chart to Pie chart.
Below code does not render any pie chart at all. The issue I think is on the data binding code that I highlighted below.
I am also including the xaml code that has been working with column chart so that you can compare them and tell me what I am doing wrong.
Thank you!
<UserControl.Resources>
        <local:ScorecardBusinessLogic x:Key="ScorecardData"/>
</UserControl.Resources>
<Border Background="White" CornerRadius="8" Grid.Row="4" Grid.Column="2" Grid.RowSpan="4" Grid.ColumnSpan="2" BorderThickness="1" Margin="2,5,5,5" BorderBrush="Gray">
            <StackPanel >
                <Border CornerRadius="2" Opacity="0.8">
                    <Border.Background>
                        <LinearGradientBrush StartPoint="0,0" EndPoint="1,0">
                            <LinearGradientBrush.GradientStops>
                                <GradientStopCollection>
                                    <GradientStop Offset="0" Color="#CCffcc00" />
                                    <GradientStop Offset="0.988" Color="#CCFF6700" />
                                    <GradientStop Offset="1" Color="#CCff6600" />
                                </GradientStopCollection>
                            </LinearGradientBrush.GradientStops>
                        </LinearGradientBrush>
                    </Border.Background>
                    <TextBlock Text="Your Overall Work Rating Scorecard for the Past 12 Months" HorizontalAlignment="Center" Margin="1" FontWeight="Bold"/>
                </Border>
                <igChart:XamWebChart x:Name="xamWebChartScore" >
                    <igChart:XamWebChart.Series>
                        <igChart:Series ChartType="Pie" DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" >
                            <igChart:Series.ChartParameters>
                                <igChart:ChartParameter Type="Exploded"
                                 Value="True" />
                                <igChart:ChartParameter Type="ExplodedAnimation">
                                    <igChart:ChartParameter.Value>
                                        <igChart:Animation BeginTime="0:0:0"
                                  Duration="0:0:2.5" />
                                    </igChart:ChartParameter.Value>
                                </igChart:ChartParameter>
                            </igChart:Series.ChartParameters>
                            <igChart:Series.DataPoints>
                                <igChart:DataPoint  Value="{Binding CountA}"  Label="Satisfactory" />
                                <igChart:DataPoint   Value="{Binding CountB}" Label="Unsatisfactory Once" />
                                <igChart:DataPoint   Value="{Binding CountC}" Label="Unsatisfactory twice"  />
                                <igChart:DataPoint   Value="{Binding CountD}" Label="Unsatisfactory more than twice"  />
                            </igChart:Series.DataPoints>
                        </igChart:Series>
                    </igChart:XamWebChart.Series>
                </igChart:XamWebChart>
            </StackPanel>
        </Border>
Below is the column chart code that render the column chart correctly:
Below is the original bar chart xaml with animation:
            <StackPanel >
                    <Border.Background>
                </Border>
                <igChart:XamWebChart x:Name="xamWebChartScore" Width="450" Height="280" >
                    <igChart:XamWebChart.Style>
                        <Style TargetType="igChart:XamWebChart">
                            <Setter Property="EndPaletteBrush" Value="#BFEB1C2E" />
                            <Setter Property="StartPaletteBrush" Value="#BF41C4F3" />
                            <Setter Property="Padding" Value="2" />
                            <Setter Property="Template">
                                <Setter.Value>
                                    <ControlTemplate TargetType="igChart:XamWebChart">
                                        <Border BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}">
                                            <Grid
                        x:Name="RootElement"
                        Margin="{TemplateBinding Padding}"
                        Background="{TemplateBinding Background}">
                                                <Grid.RowDefinitions>
                                                    <RowDefinition Height="Auto" />
                                                    <RowDefinition Height="*" />
                                                </Grid.RowDefinitions>
                                                <Grid.ColumnDefinitions>
                                                    <ColumnDefinition Width="*" />
                                                    <ColumnDefinition Width="Auto" />
                                                </Grid.ColumnDefinitions>
                                                <Grid
                           x:Name="CaptionPanel"
                           Grid.Column="0"
                           Grid.ColumnSpan="2"
                           Grid.Row="0" />
                                                <Grid
                           x:Name="ScenePanel"
                           Grid.Column="0"
                           Grid.Row="1" />
                                                <Grid
                           x:Name="LegendPanel"
                           MaxWidth="200"
                           Grid.Column="1"
                           Grid.Row="1" />
                                            </Grid>
                                        </Border>
                                    </ControlTemplate>
                                </Setter.Value>
                            </Setter>
                        </Style>
                    </igChart:XamWebChart.Style>
                    <igChart:XamWebChart.Scene>
                        <igChart:Scene>
                            <igChart:Scene.GridArea>
                                <igChart:GridArea BorderThickness="1,1,1,1" BorderBrush="#FFEAEAEA">
                                    <igChart:GridArea.Background>
                                        <RadialGradientBrush
                     GradientOrigin="0.187,0.242"
                     Center="0.187,0.242"
                     RadiusY="0.804"
                     RadiusX="0.804">
                                            <GradientStop Color="#FFFFFFFF" Offset="0.541" />
                                            <GradientStop Color="#FFFAFAFA" Offset="1" />
                                        </RadialGradientBrush>
                                    </igChart:GridArea.Background>
                                </igChart:GridArea>
                            </igChart:Scene.GridArea>
                        </igChart:Scene>
                    </igChart:XamWebChart.Scene>
                    <!-- Data points -->
                        <igChart:Series ChartType="Column" DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" DataMapping="Value=CountA"
                    DataPointStyle="{StaticResource ColumnChart}" Animation="{StaticResource DataPointAnimation}" Label="A">
                            <igChart:Series.Fill>
                                <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
                                    <GradientStop Color="#FFC5F80B" />
                                    <GradientStop Color="#FF6B8901" Offset="1" />
                            </igChart:Series.Fill>
                        </igChart:Series>
                        <igChart:Series DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" DataMapping="Value=CountB" ChartType="Column"
                    DataPointStyle="{StaticResource ColumnChart}" Animation="{StaticResource DataPointAnimation}" Label="B">
                                    <GradientStop Offset="0" Color="#FF99ffff" />
                                    <GradientStop Offset="1" Color="#FF6dbdd1" />
                        </igChart:Series>
                        <igChart:Series DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" DataMapping="Value=CountC" ChartType="Column"
                    DataPointStyle="{StaticResource ColumnChart}" Animation="{StaticResource DataPointAnimation}" Label="C">
                                    <GradientStop Color="#FFFFA733" />
                                    <GradientStop Color="#FFB25318" Offset="1" />
                        </igChart:Series>
                        <igChart:Series DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" DataMapping="Value=CountD" ChartType="Column"
                    DataPointStyle="{StaticResource ColumnChart}" Animation="{StaticResource DataPointAnimation}" Label="D">
                                <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0" >
                                    <GradientStop Color="Violet" />
                                    <GradientStop Color="DarkViolet" Offset="1.0" />
                        </igChart:Series>
                        <igChart:Series DataSource="{Binding Source={StaticResource ScorecardData}, Path=ScoreCards}" DataMapping="Value=CountF" ChartType="Column"
                    DataPointStyle="{StaticResource ColumnChart}" Animation="{StaticResource DataPointAnimation}" Label="F" >
                                    <GradientStop Color="#FFFF3366" />
                                    <GradientStop Color="#FFB2183E" Offset="1" />
                        </igChart:Series>
                        <!--<igChart:Series ChartType="Column" >
                        <igChart:DataPoint Value="5" Label="A" ToolTip="This is your scorecard for overall job performance. This bar is for 'A' score."/>
                        <igChart:DataPoint Value="9" Label="B" ToolTip="This is your scorecard for overall job performance. This bar is for 'B' score."/>
                        <igChart:DataPoint Value="10" Label="C" ToolTip="This is your scorecard for overall job performance. This bar is for 'C' score."/>
                        <igChart:DataPoint Value="6" Label="D"  ToolTip="This is your scorecard for overall job performance. This bar is for 'D' score."/>
                        <igChart:DataPoint Value="6" Label="F"  ToolTip="This is your scorecard for overall job performance. This bar is for 'E' score."/>
                    <igChart:Series.Animation>
                        <igChart:Animation BeginTime="00:00:01"
                               Duration="00:00:03"
                               AccelerationRatio="0.5"
                               DecelerationRatio="0.5"
                               Sequential="True" />
                    </igChart:Series.Animation>
                </igChart:Series>-->
            </StackPanel>
        </Border>
