315
WebCurrencyEditor Required Field Validation does not work?
Hi I have a WebCurrencyEditor with a required field validator, but the validator does not fire on trying to submit??? how is this supposed to work?
 <ig:WebCurrencyEditor ID="QuoteAmount" runat="server" MinDecimalPlaces="2" Nullable="False" Culture="en-ZA" DataMode="Decimal" HideEnterKey="True" CausesValidation="True"></ig:WebCurrencyEditor>
<asp:RequiredFieldValidator ID="RequiredFieldValidator2" runat="server" ControlToValidate="QuoteAmount" Display="Dynamic" ErrorMessage="Quote amount is Required!" CssClass="DDValidator" InitialValue="0">
Infragistics4.Web.v10.2, Version=10.2.20102.1011
  • 12679
    Hello Andrew,
    Thanks for your post!
    I had created a support ticket with number : CAS-57708-HYQSP9. I also  have logged this behavior with our developers in our tracking system,  with an issue ID of #61339 = “Client side validation fails to stop postback” . This development issue will be assigned to a developer to research for a resolution.
    You will be notified once the resolution is reached.
    Thank you
