40
Performing selection of a row on Infragistics Grid in Silverlight App Using QTP 10.0 (having Sliverlight Add-in)
We have a customised infragristics grid in a siliver light application. The version of Sliverlight Application is 4.0
We are trying to select a row of this grid using QTP 10.0 having silver light add-in. We are sucessful in derriving row values of .IsSelected and .Is Active in following way -
msgbox Browser("iLocates").Page("iLocates").SlvWindow("Shell").SlvObject("LocatesGrid").Object.DataContext.LocatesGrid.Rows.Item(0).IsActive
Above code gives "False" when the row is not clicked and "True" when the row is clicked.
msgbox Browser("iLocates").Page("iLocates").SlvWindow("Shell").SlvObject("LocatesGrid").Object.DataContext.LocatesGrid.Rows.Item(0).IsSelected
Above code also, gives "False" when the row is not clicked and "True" when the row is clicked.
But when we try to use the QTP script to set it to Active or Selected using either of following code
Browser("iLocates").Page("iLocates").SlvWindow("Shell").SlvObject("LocatesGrid").Object.DataContext.LocatesGrid.Rows.Item(0).IsActive = True
OR
Browser("iLocates").Page("iLocates").SlvWindow("Shell").SlvObject("LocatesGrid").Object.DataContext.LocatesGrid.Rows.Item(0).IsSelected = True
We get following exception [Arg_ArgumentException]
Arguments:
Debugging resource stringsare unavailable. Often the key and arguments provide sufficient information to diagnose the problem see http://go.microsoft.com/fwlink/?linkid=106663&Version=4.0.50917.0&File=mscorlib.dll&Key=Arg_ArgumentException
Line (60):  "Browser("iLocates").Page("iLocates").SlvWindow("Shell").SlvObject("LocatesGrid").Object.DataContext.LocatesGrid.Rows.Item(0).IsActive = True"
Seeking you advice in this case.
