I am using Infragistic treeview ,i have two nodes with checkboxes and few childnodes for those nodes, i want to select any one of the node at a time not two nodes at single time. this i want to achieve through javascript
i,e if i check a node1,other node i,e node2 automitacally should uncheck(if it is checked).
Plz Help
Thanks in advance
Sharan
Ok thanks for suggesation.....
Regards
sharan
Please, do use the forums for sharing your technical questions - a lot of people do follow the forums and chances are you will get a good answer if you post things here.
If you have private/sensitive information that you do not want to share, please use our official Developer Suppot channel for that.
Thanks.
Thanks for the reple, please will you give me your gmail or yahooid so that i can ask u doubts directly.
So, as far as I get - you need to check/uncheck all parents / children - not only immediate parents/children, but also all nodes up/down the hierarchy several levels deep, right?
Thanku very much for ur reply,i saw that function and i made few modification in that function so its working fine with the parents nodes here is that function,
var parents = tree.getNodes();
return;
var parent = parents;
if(parent.getChecked())
So I have one more requirement that is ,If i check a parent node all child node should check and vise varsa,in the same function,so can you help me.
