When I have 1 measure in the PivotGrid, the only cells that show are those where the measure has values.
When I have 2 measures in the PivotGrid, I see empty cells. Is this a bug?
To reproduce it, use the xamPivotGrid Demo, choose Basic > XMLADataSource.
Create a pivotgrid from "AdventureWorks DW 2008 SE" Database with the "AdventureWorks" cube. Use "Internet Order Count" and "Reseller Order Quantity" as measures and "Promotion End Date" as the dimension.
thanks for your question. I succeeded to reproduce your issue we will investigate it.
Dimitrina
