399
How to check on TreeItem presence at xamTree click position
Hi
I am examining whether this function can be mounted with XamTree.
1.Whether cursor under TreeItem exists when right-clicking in the xamTree area is checked.
    Problem 1
            XamTree.MouseLeftButtonDown Event is not generated even if it clicks at the cursor position of figure above.
2.Whether cursor under TreeItem exists when left-clicking in the xamTree area is checked.
    I tried to treat MouseRightButtonDown,
    and to acquire XamTreeItem that is below referring to the MouseButtonEventArgs object.
    but,
    Problem 2
     The type of OriginalSource when right-clicking outside the area of TextBlock of item7 cannot be judged as shown in figure above.
      I want to check whether there is XamTreeItem in the clicked area.
by handling XamGrid.MouseLeftButtonDown Event ,XamGrid.MouseRightButtonDown Event
Can TreeItem under the cursor be checked?
Please cooperate if there is a good method of settlement.
Sorry to trouble you. Thank you for taking care of it.
regards.
Parents
No Data
Reply
  • 399
    Verified Answer
    Settlement of the issue:
    I retrieve TreeViewItem of VisualTreeHelper by using e.OriginalSource.
    static method:
            static DependencyObject VisualUpwardSearch<T>(DependencyObject source)
                while (source != null && source.GetType() != typeof(T))
                    source = VisualTreeHelper.GetParent(source);
                return source;
    MouseLeftButtonDown Event:
            private void xamTreeEx_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
                XamTreeItem treeViewItem = VisualUpwardSearch<XamTreeItem>(e.OriginalSource as DependencyObject) as XamTreeItem;
                if (treeViewItem != null)
                    //When there is XamTreeItem in the area
                else
                    //When there is no XamTreeItem in the area
    Thus, I was able to check whether XamTreeItem existed in the clicked area.
    The problem was solved.
    regards.
Children
No Data
