Simple xaml with no code behind:
<UserControl x:Class="SL.InfragisticsContextMenu.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ig="clr-namespace:Infragistics.Controls.Menus;assembly=InfragisticsSL4.Controls.Menus.XamMenu.v10.3"> <ig:ContextMenuService.Manager> <ig:ContextMenuManager> <ig:ContextMenuManager.ContextMenu> <ig:XamContextMenu x:Name="mnuContext" Height="Auto" Width="Auto" HorizontalAlignment="Left" VerticalAlignment="Top"> <ig:XamMenuItem x:Name="mnuName" Header="Some Header"/> </ig:XamContextMenu> </ig:ContextMenuManager.ContextMenu> </ig:ContextMenuManager> </ig:ContextMenuService.Manager> <Grid x:Name="LayoutRoot" Background="White"> <Button Content="Button" Height="100" Width="100"/> </Grid></UserControl>
1. set project properties under Debug tab: Start action: out-of-browser application
2. Start Debugging.
3. OOB window will appear, you can resize it without problem.
4. Right click to bring out the context menu. Click anything inside or outside the menu.
5. Try to resize window again -> all window content disappears.
Seems like a bug to me, or am I missing something here?
Art
Sorry for the delay.
I was able to reproduce your issue with the 10.3 Volume Release version and I am assuming you are using the same version as well.
However, there is a Service Release coming out in few days that should fix that problem.
Thanks for reporting the issue and hope that helps,
Any feedback on this?
