Hi ,
I came across an issue during the development of a business application, when using several XamWebGrid (2010.1) in a TabControl.
I made a little sample project that i attached to this message, where you can reproduce the problem. Here are the steps :
When the app is launched :
- on the tabitem1 tab, make group by on 3 or 4 columns (drag column header)
- Click the "add" button on the bottom right corner
- Go to the tabitem2 tab
- Come back on tabitem 1
- Choose a column to group by, and drag its header to the beginning of the group by area ( on the first group by header).
At this point i Get a NullReferenceException...
On my business app, i just need to drag the group by column header anywhere on the group by area to raise this exception, not only the beginning. But i can't manage to have a sample application that has the exact same problem. But still, it's almost the same :)
Thanx
Thanx ! I'm looking forward to it, so . :)
Ok, i was able to reproduce with that build.
So this issue is fixed in the next SR, which should be out within the next 1 -2 weeks.
-SteveZ
Sure.
The Infragistics assemblies are on version 10.1.10101.2081. I think it's the last SR, right ?
I wasn't able to reproduce, but i'm using the build that will be used for the next SR.
Can you tell me what build of 10.1 you're using, so that i can verify that its definitely fixed for the upcoming SR?
