515
xamgrid binding into XamTileView
Hello, if I put the XamGrid into TilePane the ItemSource give me an error:
Riferimento a un oggetto non impostato su un'istanza di oggetto.
If put then XamGrid outer of TilePane the ItemSource is Ok
This is the Code:
<ig:XamTileView ColumnsInPage="2" RowsInPage="2" Name="tlOre">
<ig:TilePane Header="Fascia oraria" Name="tpOre" >
<ig:XamGrid Name="dgOre" AutoGenerateColumns="False" VerticalAlignment="Stretch">
<ig:XamGrid.Columns>
<ig:TextColumn HeaderText="Ora" Key="Descrizione"/>
<ig:TextColumn HeaderText="Venduto" Key="Valore"/>
</ig:XamGrid.Columns>
</ig:XamGrid>
</ig:XamTileView>
VB
Private Sub mService_GetFasciaOrariaCompleted(ByVal sender As Object, ByVal e As ServiceReference1.GetFasciaOrariaCompletedEventArgs) Handles mService.GetFasciaOrariaCompleted
dgOre.ItemSource = e.Results
End sub
Thank you
Alessandro
(italy)
