455
WebDialogWindow in Ascx user control inside a webtab
I am trying to get a reference to a web dialog window located on an ascx page loaded into a tab. In javascript I tried everything I know and still the object returned is not a web dialog window. Any help?
 Tried all of these
dialogWindowID = "ctl00_mainPageContent_UltraWebTab1__ctl4_ctl00_WebDialogWindow1"
var dialog1 = $get(dialogWindowID);
var dialog2 = igtab_getElementById(dialogWindowID);
var webTab = igtab_getTabById("ctl00_mainPageContent_UltraWebTab1");
if(webTab != null)
  var dialog3 = webTab.findControl(dialogWindowID);
  • 24497
    To get reference to any "javascript" object like WebDialogWindow regardless where it is located, you should use its objects, but not its parent.
    For example, if you need its id, then you may process ClientEvents.Initialize="initCtrl":
    var globalRefToDialog = null;
    function initCtrl(sender, args)
      globalRefToDialog = sender;
    //alert(sender.get_id());
