570
WebCombo with UpdatePanel bug
I use v10.2.20102.2101
I have a simple webpage with a  : ScriptManager, UpdatePanel,WebDialogWindow,button and webCombo
When i have the combo and WebDialogWindow  in the page and i run my webpage i does'nt see the page.
If i delete the WebDialogWindow  my page work  or if i delete the combo my page work. the both control in same page do the problem.
What is the solution?
Here is my code of webpage doesn't work with webcombo:
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="wfBug_Dialog.aspx.vb" Inherits="WebPortailCegertec.wfBug_Dialog" %>
<%@ Register assembly="Infragistics35.Web.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.LayoutControls" tagprefix="ig" %>
<%@ Register assembly="Infragistics35.WebUI.WebCombo.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.WebCombo" tagprefix="igcmbo" %>
<%@ Register assembly="Infragistics35.WebUI.UltraWebGrid.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head1" runat="server">
    <title></title>
    <link href="../../Styles/StyleChargement.css" rel="stylesheet" type="text/css" />
     <link href="../../Styles/controle.css" rel="stylesheet" type="text/css"/>
</head>
<body>
    <form id="form1" runat="server"  enableviewstate="True">
        <!-- Le ScriptManager est nécéssaire pour faire fonctionner le (UpdatePanel ou WebDialogWindow)  -->
        <asp:ScriptManager ID="scriptMgr" runat="server" />
        <!-- Cette section est miss a jours sur le PostBack -->
        <asp:UpdatePanel ID="updatePnl" runat="server">
            <ContentTemplate>
                <fieldset>
                <legend>Panel Title</legend>
                    <igcmbo:WebCombo ID="WebCombo1" runat="server" Version="4.00">
                        <ExpandEffects ShadowColor="LightGray" />
                        <Columns>
                            <igtbl:UltraGridColumn>
                                <header caption="Column0">
                                </header>
                            </igtbl:UltraGridColumn>
                        </Columns>
                        <DropDownLayout Version="4.00">
                            <framestyle height="130px" width="325px">
                            </framestyle>
                        </DropDownLayout>
                    </igcmbo:WebCombo>
                    <asp:Button ID="btnPrint" runat="server" OnClientClick="btnPrint_Click"
                        Text="Imprimer" Width="133px" />
                    <!-- Code pour avoir le message de : chargement en cours -->
                    <asp:UpdateProgress ID="siteUpdateProgress" runat="server"
                        AssociatedUpdatePanelID="updatePnl" DisplayAfter="100" DynamicLayout="true">
                        <ProgressTemplate>
                            <div class="Sample5PageUpdateProgress">
                                <asp:Image ID="ajaxLoadNotificationImage" runat="server"
                                    AlternateText="[image]" ImageUrl="~/images/ajax-loader.gif" />
                                <br />
                                <span style="color:Black">Chargement en cours... &nbsp;</span>
                            </div>
                        </ProgressTemplate>
                    </asp:UpdateProgress>
                </fieldset>
            </ContentTemplate>
        </asp:UpdatePanel>
        <ig:WebDialogWindow ID="wdwMessage" runat="server" Height="300px"
            Width="400px" WindowState="Hidden">
        </ig:WebDialogWindow>
    </form>
</body>
</html>
