Hi
Can anyone please let me know, if the new release Silverlight 4.0.50917.0 effects the usage of infragistics tools, because my application is crashing am not even able to open the xaml designer in visual studio,.. i.e. open the application..?
Hi Harisha,
We have also tried on a few different project with Silverlight 4.0.50917.0 and we didn’t encounter any issue. I would suggest searching in the Microsoft forums for this error so you may find something helpful. Thank you.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Hi Dimi
The problem or issue still persists but I don't its any way related to Infragistics and I am yet to figure out the actual root cause.
Thanks for following up though.
Hi Harisha
Just checking if you still has issue with Infragistics tools or you manage to get your project working. Please let me know if you need any further assistance on the matter.
Hi Harisha, The new Silverlight build 4.0.50917.0 must not effect the usage of infragistics tools. You could use it without any issues. I'm also using the same build and have no problems. Infragistics components are built against Silverlight 4 RTM and you could use it with latest build.
Best!
Mihail
