I am using 2010 V1 and a problem that faced that in XamWebComboEditor if we asssign a numeric property to DisplayMemberPath and have CutsomItemsFilter then it rasie SelectionChanged Event Twice and selection is done to first item in list.
Is this a bug or we have some problem with code
Hi Imran Javed Zia,
I've investigated the issue and when not debugging the application it is working as expected - firing once SelectionChanged Event and selecting correct item.
When we asssign a numeric property to DisplayMemberPath and have CutsomItemsFilter property set to NotEquals condition in debug mode the problem is existing because there is logic on LostFocus event.
Best regards,Milena MitovaSoftware Engineer in Test INetAdvantage for Silverlight LoB
