445
access Button control from template column in XamWebGrid_InitializeRow event
Is there any way to access Button control from template column in XamWebGrid_InitializeRow event ?
<igGrid:TemplateColumn Key="Edit" Width="50">
                                                <igGrid:TemplateColumn.ItemTemplate>
                                                    <DataTemplate>
                                                        <Button x:Name="BtnEditParameter" Content="Edit" Visibility="{Binding IsEdit}" Width="50"></Button>
                                                    </DataTemplate>
                                                </igGrid:TemplateColumn.ItemTemplate>
                                            </igGrid:TemplateColumn>
I want to access BtnEditParameter on XamWebGrid_InitializeRow event.
Please suggest.
-Pankaj
  • 8421
    Suggested Answer
    The InitializeRow event is too early in the order of events for the XamGrid. A better event to use is the CellControl attached event, which will also allow you update the button when values change. You can access the button by using e.Cell.Control.Content.
