1995
Freezing Columns in UltraWebGrid
Dear Sir,
           I am using Ultrawebgrid to populate my dataset. When I try to Freeze columns in my grid, i was able to freeze only the First row of the grid. Is it possible to freeze the columns that were selected by the user at runtime? If so kindly reply.
  • 29417
    Suggested Answer
    Hello sureshsimkumar ,
    Setting the Fixed property of the header can be done only on a full page postback on the server. Any changes to this property regardless if they're made from the JS or through an async postback are no persisted.
    You can simulate this by adding a button to the form and in its click event do the following:
    protected void Button1_Click(object sender, EventArgs e)
            UltraWebGrid1.Columns[0].Header.Fixed = true;
    Let me know if you have any further questions regarding this issue.
    Best Regards,
    Maya Kirova
    Developer Support Engineer
    Infragistics, Inc.
    http://es.infragistics.com/support
