Hello there,
I need to develop a web based application using .net 3.0 and I need to use Infragistics grid control. Please suggest me :-
Thanks in advance.
I am following up to see if you have any further questions with this matter.
Update me if you need any further assistance.
WebDataGrid is built on top of the Infragistics ASP.NET AJAX framework. It is an efficient and scalable grid control, with native AJAX capabilities. WebDataGrid incorporates an intuitive, easy-to-use design interface, allowing you to customize every aspect of its functionality with ease. Furthermore, WebDataGrid is also supported across modern browsers. Please review the links that will give you more details on WebDataGrid samples and Documentation:
<http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebDataGrid_About_WebDataGrid.html>
<http://samples.infragistics.com/aspnet/ComponentOverview.aspx?cn=data-grid>
<http://help.infragistics.com/NetAdvantage/ASPNET/201.1/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html>
If you are planning to use ASP.NET controls the downlaod “NetAdvantage for ASP.NET 2011 Vol. 1 Complete Bundle” since its size is less than “NetAdvantage Ultimate 2011 Vol. 1”.
