3521
Changing to Templated Column Causes Editmode to Not Be Entered
I am using SL LOB 2009.2 release 2099
I wanted to change a column to have stacked headers because the header text was wider than the data, and I need the real estate.  The users need to be able to enter data into this column.  When I changed it to a templated column, I can no longer edit in that cell.  Any ideas?
So, I changed the XAML for this column from:
  506                 <igGrid:TemplateColumn Key="PercWorkComplete"
  507                                       Width="0.5*"
  508                                       HeaderText="%WorkComplete"
  509                                       CellStyle="{StaticResource myCellMainRow}">
  510                     <igGrid:TemplateColumn.ItemTemplate>
  511                         <DataTemplate>
  512                             <TextBlock Text="" />
  513                         </DataTemplate>
  514                     </igGrid:TemplateColumn.ItemTemplate>
  515                 </igGrid:TemplateColumn>
To:
  517                 <igGrid:TemplateColumn Key="PercentComplete"
  518                                       HorizontalContentAlignment="Center"
  519                                       CellStyle="{StaticResource myCellMainRow}"
  520                                       ValueConverter="{StaticResource NumConverter}"
  521                                       ValueConverterParameter="{StaticResource PercentFormat}"
  522                                       EditorStyle="{StaticResource myEditorStyleTextBox}"
  523                                       Width="0.5*">
  524                     <igGrid:TemplateColumn.HeaderTemplate>
  525                         <DataTemplate>
  526                             <TextBlock HorizontalAlignment="Center"
  527                                       Text="%Work Complete"
  528                                       TextWrapping="Wrap" />
  529                         </DataTemplate>
  530                     </igGrid:TemplateColumn.HeaderTemplate>
  531
  532                     <igGrid:TemplateColumn.ItemTemplate>
  533                         <DataTemplate>
  534                             <TextBlock Text="{Binding PercentComplete, Mode=TwoWay, Converter={StaticResource NumConverter}, ConverterParameter={StaticResource PercentFormat}}" />
  535                         </DataTemplate>
  536                     </igGrid:TemplateColumn.ItemTemplate>
  537
  538                 </igGrid:TemplateColumn>
  • 3521
    Verified Answer
    Uh, nevermind.  On a whim, I tried something out and I answered my own question.  The issue was lines 520 and 521.  Those are not needed in that section
