From the documentation, it seems there is no standard xamGrid to excel exporter.
I've seen this forum post : http://forums.infragistics.com/forums/t/34069.aspxThe sample is not up to date, but can serve as a workaround, so I'll use this for now.
When will a standard exporter be available? I don't want to maintain my own exporter that will most likely be buggier than an standard exporter provided by infragistics.
HI,
You will be contacted when and if the feature request gets implemented.
We should probably close the case. Closing the case will have no impact on when and if the feature gets implemented.
Sincerely, Matt Developer Support Engineer
Thanks Matt,
Do you need addtional input? The feature request is listed as "Awaiting customer Action".
Regards,Julien
I will submit a feature request for this issue.
Sincerely,
MattDeveloper Support Engineer
