285
Progress Indicator
I am trying to implement our customer Progress indicator since there is no default ones available in the pivotGrid. What events would I subscribe to that would give me the start of executing a command and the end of execution?
  • 8831
    If you are looking for a property that can gives you information about whether query execution (adding/removing hierarchies or measures) is in progress you can try DataSourceBase.Processing property. It has a value of true until the async operation is not completed.
    Please let me know if that covers your needs.
    Regards.
    PPilev.
  • 816
    Suggested Answer
    Check out some of the following events:
    PivotGrid.DataSource.Columns.CollectionChanged
    PivotGrid.DataSource.Rows.CollectionChanged
    PivotGrid.DataSource.Filters.CollectionChanged
    PivotGrid.DataSource.Measures.CollectionChanged
    and/or
    PivotGrid.AxisExpansionChanged
    PivotGrid.ColumnSorted
    PivotGrid.SelectedColumnsCollectionChanged
    PivotGrid.SelectedRowsCollectionChanged
    You can set your indicator on some of these events, and then clear it on
    PivotGrid.DataSource.ResultChanged
    Hope that helps.
