Hii,
Using the Infragistics web Date Chooser, I want to hight light the any one day (Ex: All thursdays), ie particular day for color should be different from other days.
Take Example for thursday: All dates which is fall in thursdays, should be in red color.
Can anyone please help me how i can achieve this. This is very urgent requirement . Its very helpful if any one do helps to me.
Vanji
Hi svanji,
That happens because WebDateChooser uses TABLE element for its base html element. Browser uses display:block for TABLE, so, any html element will appear on new line.
If validator in aspx appears directly after WebDateChooser and WebDateChooser does not use position:absolute/relative, then you may try to use position:absolute with margins for validator (do not use left/top). Below is example for you:
<igsch:WebDateChooser ID="WebDateChooser1" runat="server" Width="150px"></igsch:WebDateChooser><asp:RequiredFieldValidator ID="RequiredFieldValidator1" runat="server" style="position:absolute; margin-top:-20px; margin-left:153px;" ControlToValidate="WebDateChooser1" ErrorMessage="*"></asp:RequiredFieldValidator>
HI, can you please answer my below question.
i used Webdate chooser in my page form. While submitting i am handlilng some validation that date got selected or not. If not selected i have to display * near of this date control. I used Required Validator like below
</CalendarLayout></ig:WebDateChooser>
<asp:RequiredFieldValidator Display="Static">*</asp:RequiredFieldValidator>
In browser * has to display after the data control. But its displaying always next line. I didn't used any <br>. If i use regular ASP:Textbox, * is getting displaying next to the control
Can you please help me to sort out this problem.
For temprary solution, i used each <td><.td> for <ig:WebDateChooser> and <asp:RequiredFieldValidator >, this is not a good solution.
Hi Svanji,
You may use NullDateLabel.
<igsch:WebDateChooser ID="WebDateChooser1" runat="server" NullDateLabel="00/00/0000"></igsch:WebDateChooser>
One more question. can you please help me to sort out.
In webdatechooser when i remove the displayed date its showing null value, instead of this i want to display 00/00/0000, how i can achieve this.
Its great that if any one help for this problem.
thanks lot, its working fine.
