I have 2 trees in a stackpanel in a grid column, I want that stackpanel to show a vertical scroll bar so as the 2 trees are expanded I can scoll down. Currently it cuts off at the bottom. I have tried using the Scrollviewer attribute on the grid, stackpanel to no avail. Is there a way to do this easily?
Here is the pseudo code...
<Grid x:Name="LayoutRoot" Background="#19246286">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="300"/>
<ColumnDefinition Width="300" />
<ColumnDefinition />
</Grid.ColumnDefinitions>
<Grid.RowDefinitions>
<RowDefinition Height="25" />
<RowDefinition Height="580" />
</Grid.RowDefinitions>
<StackPanel Orientation="Vertical" Grid.Row="1" Height="Auto" VerticalAlignment="Top" >
<ig:XamTree x:Name="xamTree1" x:FieldModifier="public" Background="#FFAED0E6">
<ig:XamTreeItem....
</ig:XamTree>
<ig:XamTree x:Name="xamTree2" x:FieldModifier="public" Background="#FFAED0E6">
<ig:XamTreeItem .......
</StackPanel>
Okay, I did a bit more research and it looks like this is an issue with how the Microsoft implemented the StackPanel. To get the scrollbars to appear, instead wrap the StackPanel with a ScrollViewer control.
I've attached a sample that demonstrates this.
No luck with this, tree grows, no scrollbar is appearing. Do you have a simple sample demonstrating this?
This should be possible by setting an explicit Height for your StackPanel (though I think this might be taken care of by setting the height on the Grid row). Also, set the StackPanel's ScrollViewer.VerticalScrollBarVisibility property to "Auto".
