I have a xamGrid that I have successfully binded data from the DB. Now I wish to allow users to delete the selected rows. I have the code deleting the selected row from the grid, but need to get the value from a hidden column within the grid to pass to my delete method to delete the row from the DB. How do I get the selected row column value from the code below?
xaml:
ig:XamGrid x:Name="dataGrid" AutoGenerateColumns="false" ColumnWidth="*" Grid.Row="2" >
<ig:TextColumn Key="PivotViewID" Visibility="Collapsed">
<ig:TextColumn.HeaderTemplate>
<DataTemplate>
<TextBlock Text="PivotViewID" />
</DataTemplate>
</ig:TextColumn.HeaderTemplate>
</ig:TextColumn>
code:
void
Deleteok_Click(object sender, RoutedEventArgs e)
foreach (Row selectedRow in dataGrid.SelectionSettings.SelectedRows)
dataGrid.Rows.Remove(selectedRow);
var proxy = new WcfServiceReference.Service1Client("BasicHttpBinding_IService1");
proxy.DeletePivotViewsCompleted +=
new EventHandler<PivotGrid.WcfServiceReference.DeletePivotViewsCompletedEventArgs>(proxy_DeletePivotViewCompleted);
proxy.DeletePivotViewsAsync(2);
//selectedRow PivotViewID ???
this.winDeleteMB.Close();
To get a value from the row you can just access the .Cells collection off the Row object
row.Cells[columnKey].Value
Or even better access the Data off the row, as this is your real data object, and get the value directly off this
MyObject myObj = (MyObject) row.Data;
