225
XamWebGrid 9.2 - ColumnWidth.SizeToHeader issues
Bsed on the code below, I am facing the following issue with XamWebGrid 9.2: -
When the ColumnWidth is set to SizeToHeader, the FixedColumnIndicator overlaps last 2-3 alphabets of the column header.
It means that the column header is not completely visible. THIS WAS WORKING FINE WITH INFRAGISTICS 9.1.
Can someone suggest whats causing the problem ? or is it a issue / enhancement in 9.2?
Here is the XAML
UserControl xmlns:controlsToolkit="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Toolkit" xmlns:controls="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls" xmlns:igGrid="clr-namespace:Infragistics.Silverlight.Controls;assembly=Infragistics.Silverlight.XamWebGrid.v9.2" x:Class="IG_Samples.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x
="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable="d" d:DesignWidth="640" d:DesignHeight
="480">
<Grid x:Name="LayoutRoot" Background="Aquamarine">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="2*"/>
<ColumnDefinition Width="*"/>
</Grid.ColumnDefinitions>
<Grid.RowDefinitions><RowDefinition Height="25"/><RowDefinition Height="*"/></Grid.RowDefinitions>
<igGrid:XamWebGrid x:Name="igGridRequestDetails" Grid.Row="1" Grid.Column="0" AutoGenerateColumns="True"HorizontalAlignment="Stretch" VerticalAlignment="Top" IsAlternateRowsEnabled="False" ActiveCellChanging="igGridRequestDetails_ActiveCellChanging" ActiveCellChanged="igGridRequestDetails_ActiveCellChanged" InitializeRow="igGridRequestDetails_InitializeRow" PageIndexChanged="igGridRequestDetails_PageIndexChanged" Filtering="igGridRequestDetails_Filtering" GroupByCollectionChanged="igGridRequestDetails_GroupByCollectionChanged" CellEnteringEditMode="igGridRequestDetails_CellEnteringEditMode" CellExitedEditMode="igGridRequestDetails_CellExitedEditMode" CellClicked="igGridRequestDetails_CellClicked" Loaded="igGridRequestDetails_Loaded">
<igGrid:XamWebGrid.GroupBySettings>
<igGrid:GroupBySettings AllowGroupByArea="Top"/>
</igGrid:XamWebGrid.GroupBySettings>
<igGrid:XamWebGrid.SortingSettings>
<igGrid:SortingSettings AllowSorting="True" AllowMultipleColumnSorting="True" ShowSortIndicator="True" />
</igGrid:XamWebGrid.SortingSettings>
<igGrid:XamWebGrid.PagerSettings>
<igGrid:PagerSettings AllowPaging="Bottom" PageSize= "25" />
</igGrid:XamWebGrid.PagerSettings>
<igGrid:XamWebGrid.ColumnMovingSettings>
<igGrid:ColumnMovingSettings AllowColumnMoving="Indicator" />
</igGrid:XamWebGrid.ColumnMovingSettings>
<igGrid:XamWebGrid.FixedColumnSettings>
<igGrid:FixedColumnSettings AllowFixedColumns="DropArea"></igGrid:FixedColumnSettings>
</igGrid:XamWebGrid.FixedColumnSettings>
<igGrid:XamWebGrid.FilteringSettings>
<igGrid:FilteringSettings AllowFilterRow="Top" FilteringScope="ColumnLayout"/>
</igGrid:XamWebGrid.FilteringSettings>
<igGrid:XamWebGrid.EditingSettings>
<igGrid:EditingSettings AllowEditing="Cell" IsMouseActionEditingEnabled="SingleClick" IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True" IsOnCellActiveEditingEnabled="True" />
</igGrid:XamWebGrid.EditingSettings>
</igGrid:XamWebGrid>
<StackPanel Orientation="Horizontal" HorizontalAlignment="Left" VerticalAlignment="Top" Grid.Row="0" Grid.Column="0" Grid.ColumnSpan="2">
<TextBlock Text="ID" />
<TextBox MinWidth="50" Name="txtID"/>
<TextBlock Text="Name" />
<TextBox MinWidth="150" Name="txtName"/>
<TextBlock Text="Joining Date" />
<controls:DatePicker Name="dtJoiningDate"></controls:DatePicker>
<TextBlock Text="Is Active" />
<CheckBox Name="chkIsActive" IsChecked="False"/>
<Button Content="Add" Click="Button_Click"></Button>
</StackPanel>
</Grid>
UserControl>
 HERE IS THE CODE
using
System;
using
System.Collections.Generic;
using
System.Collections.ObjectModel;
using
System.Linq;
using
System.Net;
using
System.Windows;
using
using
System.Windows.Documents;
using
System.Windows.Input;
using
System.Windows.Media;
using
System.Windows.Media.Animation;
using
System.Windows.Shapes;
using
Infragistics.Silverlight;
using
using
Infragistics.Silverlight.Controls.Primitives;
namespace
IG_Samples
public partial class MainPage :
UserControl
ObservableCollection<MyDataSource> objSource = new ObservableCollection<MyDataSource
public
MainPage()
InitializeComponent();
BindData();
public void
BindData()
for (int
i = 1; i <= 100; i++)
objSource.Add(
new MyDataSource() { id = i, isactive=true, joiningDate= DateTime.Today.AddDays(1), name ="test - "
+ i.ToString() });
this
.igGridRequestDetails.ItemsSource = objSource;
private void igGridRequestDetails_ActiveCellChanging(object sender, Infragistics.Silverlight.ActiveCellChangingEventArgs
e)
private void igGridRequestDetails_ActiveCellChanged(object sender, EventArgs
e)
private void igGridRequestDetails_InitializeRow(object sender, Infragistics.Silverlight.InitializeRowEventArgs
e)
private void igGridRequestDetails_PageIndexChanged(object sender, Infragistics.Silverlight.PageChangedEventArgs
e)
private void igGridRequestDetails_Filtering(object sender, Infragistics.Silverlight.CancellableFilteringEventArgs
e)
private void igGridRequestDetails_GroupByCollectionChanged(object sender, Infragistics.Silverlight.GroupByCollectionChangedEventArgs
e)
private void igGridRequestDetails_CellEnteringEditMode(object sender, Infragistics.Silverlight.BeginEditingCellEventArgs
e)
private void igGridRequestDetails_CellExitedEditMode(object sender, Infragistics.Silverlight.CellExitedEditingEventArgs
e)
private void igGridRequestDetails_CellClicked(object sender, Infragistics.Silverlight.CellClickedEventArgs
e)
private void igGridRequestDetails_Loaded(object sender, RoutedEventArgs
e)
int count = this
.igGridRequestDetails.ColumnTypeMappings.Count;
for (int
i = count - 1; i >= 0; i--)
if (this.igGridRequestDetails.ColumnTypeMappings[i].DataType == typeof(DateTime
this.igGridRequestDetails.ColumnTypeMappings[i].ColumnType = typeof(TextColumn
else if (this.igGridRequestDetails.ColumnTypeMappings[i].DataType == typeof(DateTime
private void Button_Click(object sender, RoutedEventArgs
e)
this.objSource.Add(new MyDataSource() { id = int.Parse(this.txtID.Text), name = this.txtName.Text, joiningDate = DateTime.Parse(this.dtJoiningDate.Text), isactive = bool
.Parse(chkIsActive.IsChecked.ToString())});
public class
MyDataSource
public int id { get; set
public DateTime joiningDate { get; set
public string name { get; set
public bool isactive { get; set
