2320
SelectionChanging and abort selection
Running Infragistics 10.1
I basically just want to be able to stop in the middle of a user selecting a node, check a modified flag, popup a prompt asking if they want to save with a Yes, No Cancel.  When the Tree's SelectionChanged even fires, the code-behind calls an application controller interface to perform a request.  Before it performs the request it checks a boolean flag that specifies if there are any modifications they will lose.  I have it all working except cancel.  When the modal dialog pops up, user clicks cancel, since the UI thread completed, I had code that would reselect the previously selected item and set the XamWebTreeItem.IsSelected back to true.  But I then have this weird behavior where it appears that 2 nodes are selected until you hover over the aborted node and then it shows unselected.  I tried clearing the trees collection, tried setting IsExpanded hoping it would cause node to be redrawn correctly, nope, didn't work.  Tried adding item to Selected collection, nope same behavior.
I then figured, if there was a SelectionChanging event, I could test for the changes there, and abort.  Since I don't see that event I was wondering if there is any other event I could use?  Could I implement the MouseLeftButtonDown event?  If so how could I detect there that the user is trying to select another node?
Sorry for the long winded post..  Just out of ideas.  I can always just ditch the "Cancel" option for now and just go with Yes, No but was hoping maybe there was an easier way to abort node selection programmatically.
