60
How to change width of box chart?
Hello
I'd like to change width of box chart with following codes :
void server_GetGraphDataCompleted(object sender, GetGraphDataCompletedEventArgs e)
            List<GraphEntity> result = e.Result;
            Animation animation = new Animation();
            animation.BeginTime = TimeSpan.Zero;
            animation.Duration = TimeSpan.FromSeconds(1);
            animation.Sequential = true;
            Series seriesBT = new Series();
            seriesBT.Label = "BT";
            seriesBT.ChartType = ChartType.Line;
            seriesBT.DataMapping = "Label=ColumnTime;Value=BTValue";
            seriesBT.DataSource = result;
            seriesBT.Animation = animation;
            webChart.Series.Add(seriesBT);
            Series seriesSP = new Series();
            seriesSP.Label = "SpO2";
            seriesSP.ChartType = ChartType.Line;
            seriesSP.DataMapping = "Label=ColumnTime;Value=SpO2Value";
            seriesSP.DataSource = result;
            seriesSP.Animation = animation;
            webChart.Series.Add(seriesSP);
            var resultForBoxChart = from c in e.Result
                                    select new BoxChartEntity
                                        Label = c.ColumnTime.Value,
                                        Max = c.Open,
                                        Q3 = c.Open,
                                        Q2 = ((c.Open + c.Close) / 2),
                                        Q1 = c.Close,
                                        Min = c.Close
            Series seriesABP = new Series();
            seriesABP.Label = "ABP";
            seriesABP.ChartType = ChartType.Box;
            seriesABP.DataMapping = "Label=ColumnTime;Max=Max;Q3=Q3;Q2=Q2;Q1=Q1;Min=Min";
            seriesABP.DataSource = resultForBoxChart;
            seriesABP.Animation = animation;
            seriesABP.StrokeThickness = 0;
            seriesABP.Width = 10;
            webChart.Series.Add(seriesABP);
However, even though I change the width of box type chart, it is not working
What did I wrong?
Thanks in advance
Kwon
