310
Xamgrid master / details failed
I trying to create master/details interface with XamGrid,
and I have seen that when I'm navigated on the XamGrid the selecteditem was always the same, you can constate this by using the SelectedRowsCollectionChanged event.
So when I bind a texblock with the SelectedItem it's always the first row of the Xamgrid who is displaying.
Can you help or tell me the way to make it work?!?
If I do the same with the VS2010 controls it's working fine (the textblock content is following the grid selected item), and  just by drag an drop, why not with Infragistics control??!!??
Thanks.
Gilles P
  • 635
    I accomplish this by setting a cell clicked action on the grid, and setting the Selection settings.
    <igGrid:XamGrid CellClicked="Click_Cell"  ... >
    (columns, other settings)
    <igGrid:XamGrid.SelectionSettings>
        <igGrid:SelectionSettings CellClickAction="SelectRow"
        CellSelection="None" ColumnSelection="None"
        RowSelection="Single" />
    </igGrid:XamGrid.SelectionSettings>
    </igGrid:XamGrid>
    When the cell is clicked, you can get the row by doing the following:
    MyRowType SelectedItem { get; set; }
    private void Click_Cell(object sender, CellClickedEventArgs e)
          SelectedItem = e.Cell.Row.Data as MyRowType;
  • 21382
    Suggested Answer
    We don't currently expose a SelectedItem property like the DataGrid, it is a feature on our backlog.
    But if you are using the event, do you have Selection turned on?
    test.SelectionSettings.RowSelection = Infragistics.Controls.Grids.SelectionType.Single;
                test.SelectionSettings.CellClickAction = Infragistics.Controls.Grids.CellSelectionAction.SelectRow;
    If you don't turn RowSelection on, then you will only be Activating the row when clicking it. not selecting it.
