3590
Adding vertical/horizontal crosshairs to xamdatachart?
I see some documentation on how to add vertical or horizontal crosshairs independently to the xamwebchart but it appears that this ability is not available to the xamdatachart. Is this true or have I missed something? Is there a way I can hide the horizontal crosshair on the xamdatachart? If not, what is the functional diffeerence in the xamdatachart and the xamwebchart besides the ability to handle a lot more data points? What is the limit where you would recommend moving to the datachart?
Mike
Parents
  • 30692
    Mike,
    Independent control of the visibility of the crosshairs is not currently a feature of the XamDataChart. Ideally there would be no missing features migrating between XamWebChart and XamDataChart but there are currently some missing due to scheduling constraints, most notably there are some series types available in XamWebChart that are not currently available in XamDataChart.
    That being said there are lots of new features in XamDataChart that aren't present in XamWebChart, above and beyond all the performance improvements. For example, there are no longer any restrictions on which series types can share the same plotting area, axes support inversion, unlimited number of axes are supported, multiple charts can syncrhonize their panning and zooming, labels, legends, tooltips support rich content, etc. XamDataChart also supports some new series types that XamWebChart does not currently support.
    I would suggest contacting our product management and they may be able to give you a more detailed and sanctioned view into the strategy for these in the coming releases. Its possible that the marketing info on the website is the best publishable info in this respect, however.
    In the meantime, here's a nifty behavior that can help you hide the horizontal or vertical crosshair for a chart:
    This is how to attach the behavior to the chart:
            <ig:XamDataChart Name="xamDataChart1"
                             CrosshairVisibility="Visible">
                <local:ChartBehaviors.CrosshairHiding>
                    <local:CrosshairHidingBehavior
                        HideHorizontalCrossHair="True" />
                </local:ChartBehaviors.CrosshairHiding>
            </ig:XamDataChart>
    Here is the supporting code:
    public class ChartBehaviors
            : DependencyObject
            public static readonly DependencyProperty CrosshairHidingProperty =
                DependencyProperty.RegisterAttached("CrosshairHiding",
                typeof(CrosshairHidingBehavior), typeof(ChartBehaviors),
                new PropertyMetadata(null,
                    (o, e) => CrosshairHidingChanged(
                        o as XamDataChart,
                        e.OldValue as CrosshairHidingBehavior,
                        e.NewValue as CrosshairHidingBehavior)));
            public static CrosshairHidingBehavior GetCrosshairHiding(
                DependencyObject target)
                return target.GetValue(CrosshairHidingProperty)
                    as CrosshairHidingBehavior;
            public static void SetCrosshairHiding(
                DependencyObject target, CrosshairHidingBehavior behavior)
                target.SetValue(CrosshairHidingProperty, behavior);
            private static void CrosshairHidingChanged(
                XamDataChart chart,
                CrosshairHidingBehavior oldValue,
                CrosshairHidingBehavior newValue)
                if (chart == null)
                    return;
                if (oldValue != null)
                    oldValue.OnDetach(chart);
                if (newValue != null)
                    newValue.OnAttach(chart);
        public class CrosshairHidingBehavior
            private Style _invisibleStyle;
            public CrosshairHidingBehavior()
                _invisibleStyle = new Style(typeof(Line));
                _invisibleStyle.Setters.Add(
                    new Setter(Shape.StrokeThicknessProperty, 0));
            public bool HideHorizontalCrossHair { get; set; }
            public bool HideVerticalCrossHair { get; set; }
            public void OnAttach(XamDataChart chart)
                chart.MouseEnter += Chart_MouseEnter;
            public void OnDetach(XamDataChart chart)
                chart.MouseEnter -= Chart_MouseEnter;
                MakeVisible(chart, _vertical);
                MakeVisible(chart, _horizontal);
                _vertical = null;
                _horizontal = null;
                _first = true;
            private bool _first = true;
            private Line _vertical;
            private Line _horizontal;
            private void MakeInvisible(
                XamDataChart chart, Line crosshairLine)
                crosshairLine.Style = _invisibleStyle;
            private void MakeVisible(
                if (chart == null || crosshairLine == null)
                    return;
                crosshairLine.Style = chart.CrosshairLineStyle;
            void Chart_MouseEnter(object sender, MouseEventArgs e)
                XamDataChart chart = sender as XamDataChart;
                if (_first && chart != null)
                    _first = false;
                    var crosshairs =
                        from line in chart.VisualDescendants()
                        where line is Line &&
                              (line as Line).Style
                              == chart.CrosshairLineStyle
                        select line as Line;
                    List<Line> lines = crosshairs.ToList();
                    if (lines[0].X1 == lines[0].X2)
                        _vertical = lines[0];
                        _horizontal = lines[1];
                    else
                        _vertical = lines[1];
                        _horizontal = lines[0];
                    if (HideHorizontalCrossHair)
                        MakeInvisible(chart, _horizontal);
                    if (HideVerticalCrossHair)
                        MakeInvisible(chart, _vertical);
        public static class Extensions
            public static IEnumerable<DependencyObject> VisualDescendants(
                this DependencyObject current)
                yield return current;
                for (int i = 0;
                    i < VisualTreeHelper.GetChildrenCount(current);
                    i++)
                    DependencyObject child =
                        VisualTreeHelper.GetChild(current, i);
                    foreach (
                        DependencyObject sub in child.VisualDescendants())
                        yield return sub;
    If you have any more questions, let me know. Hope this helps!
    -Graham
Reply Children
No Data
