I need to add a root node to the treeview after databinding it to a datatable. Is this possible?? (Something similar we do for a dropdownlist, like inserting a blank option after datainding with the ddl.insert(0, "Please choose"))
basically, I need to have a hardcoded root node in the treeview.
Yes, I can see where this is indeed convenient. Actually, we need a property like AppendDataBoundNodes, to persist what is currently available in the treeview prior to databinding - this way it would be much easier to just add one root node and proceed with databinding from there.
In any case, I believe the easiest solution in this case would be to create one additional DataTable in your DataSet (I assume you are using several related DataTables inside a DataSet) - this DataTable will only hold one item that is root.
An alternative approach would be to clone nodes from one tree to another - first bind a treeview and then use cloning to populare another: There is some sample code for this here:
http://forums.infragistics.com/forums/t/1731.aspx
Hope this helps.
