130
UltraWebGrid: "Index was outside the bounds of the array."
I'm getting the following error below. Can anyone suggest where I should begin looking for the error that is eliciting this message or is this indigenous to the Infragistics UltraWebGrid? And if indigenous to the UWG, is there a fix available?
TIA!
Justin
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[IndexOutOfRangeException: Index was outside the bounds of the array.]
   Infragistics.WebUI.UltraWebGrid.HeadersCollection.Render(StringBuilder res, GridRendererBase r, String indent) +86
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderColumnsHeaders(StringBuilder res, UltraGridBand band, String indent) +11632
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderBandsArray() +843
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderPostJavaScript(String extraParam) +1402
   Infragistics.WebUI.UltraWebGrid.RenderXmlGrid.VisitObjects(HtmlTextWriter output) +807
   Infragistics.WebUI.Shared.RendererBase.Render(HtmlTextWriter output) +36
   Infragistics.WebUI.UltraWebGrid.GridRendererBase.Render(HtmlTextWriter output) +381
   Infragistics.WebUI.UltraWebGrid.UltraWebGrid.Render(HtmlTextWriter output) +447
   System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22
   System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199
   System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20
   System.Web.UI.Control.Render(HtmlTextWriter writer) +7
   Infragistics.WebUI.UltraWebTab.DhtmlRenderer.RenderContent(Boolean tr, String noBorder) +2867
   Infragistics.WebUI.UltraWebTab.DhtmlRenderer.RenderControl() +2203
   Infragistics.WebUI.UltraWebTab.RendererBase.VisitObjects(HtmlTextWriter output) +125
   Infragistics.WebUI.UltraWebTab.UltraWebTab.Render(HtmlTextWriter output) +685
   System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +59
   System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +68
   System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +37
   System.Web.UI.Page.Render(HtmlTextWriter writer) +26
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2558
Version Information: Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433
