446
WebMaskEdit and Optional Mask fields
If a mask edit position is optional, why is the user required to enter it before moving onto the next valid position?
Example1:
<igtxt:WebMaskEdit ID="WebMaskEdit1" runat="server" InputMask="?0" />
  • Optional Character & Required Digit
  • You cannot tab into field and simply type the required Digit
    • you are REQUIRED to type the OPTIONAL letter (hmmm...)
Example 2:
        <igtxt:WebMaskEdit ID="WebMaskEdit2" runat="server" InputMask="99.99" />
  • All digits optional, but decimal is part of mask
  • You cannot simply type ".99"
    •  instead this will ignore the fact that you omitted the optional digits and you typed "."
    • This will  display "99."
  • You cannot simply type "9.99"
    • instead this will ignore the fact that you omitted the optional digits and typed "."
    • This will display "99.9"
  The ajax control toolkit works properly with thier mask edit http://www.asp.net/ajax/ajaxcontroltoolkit/Samples/MaskedEdit/MaskedEdit.aspx
  • On the MS control, when i type a decimal point, it takes me to the decimal position
Is there any property that changes the way this works?
