Please look at image :
Hello Shashank,
These are not empty rows, this is the background image of the ElectricBlue style. If you would like to remove it, you should remove the background image from the css class igtbl_ElectricBlueControl, that is in ig_res/ElectricBlue/ig_grid_opt.css.
Hope this helps.
Lyuba
Developer Support Engineer
www.infragistics.com/support
-Version : Infragistics35.WebUI.UltraWebGrid.v10.1, Version=10.1.20101.1011
- Source Code : ( I am choose (ElectricBlue) style for grid) :
<igtbl:ultrawebgrid id="UltraWebGrid1" runat="server" height="424px" width="100%" CaptionAlign="Right"> <Bands> <igtbl:UltraGridBand> <Columns> <igtbl:UltraGridColumn BaseColumnName="Code" HeaderText="" Key="Code"> <Header Caption="الكود"> </Header> <HeaderStyle Font-Names="Tahoma" Font-Size="Small" /> <CellStyle HorizontalAlign="Center" Font-Names="Tahoma" Font-Size="X-Small"> </CellStyle> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Description" HeaderText="" Key="Description" Width="100%"> <Header Caption="الوصف"> <RowLayoutColumnInfo OriginX="1" /> </Header> <HeaderStyle HorizontalAlign="Center" Font-Names="Tahoma" Font-Size="Small" /> <CellStyle HorizontalAlign="Center" Font-Names="Tahoma" Font-Size="X-Small"> </CellStyle> <Footer> <RowLayoutColumnInfo OriginX="1" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Update" HeaderText="??" Key="Update" CellButtonDisplay="Always" HeaderClickAction="Select" Type="Button"> <Header Caption="تعديل" ClickAction="Select"> <RowLayoutColumnInfo OriginX="2" /> </Header> <CellButtonStyle BackColor="Transparent" BackgroundImage="~/RSF/cal_date_picker.gif" BorderStyle="None" Height="13px" HorizontalAlign="Center" VerticalAlign="Middle" Width="15px"> </CellButtonStyle> <HeaderStyle Font-Names="Tahoma" Font-Size="Small" /> <CellStyle HorizontalAlign="Center" Cursor="Hand" VerticalAlign="Middle" Font-Names="Tahoma" Font-Size="X-Small"> </CellStyle> <Footer> <RowLayoutColumnInfo OriginX="2" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Delete" CellButtonDisplay="Always" HeaderClickAction="Select" HeaderText="" Key="Delete" Type="Button" Hidden="True"> <CellButtonStyle BackColor="Transparent" BackgroundImage="~/RSF/logoff_small.gif" BorderStyle="None" Height="15px" HorizontalAlign="Center" VerticalAlign="Middle" Width="15px"> </CellButtonStyle> <HeaderStyle Font-Names="Tahoma" Font-Size="Small" /> <CellStyle HorizontalAlign="Center" Font-Names="Tahoma" Font-Size="X-Small"> </CellStyle> <Header Caption="حذف" ClickAction="Select"> <RowLayoutColumnInfo OriginX="3" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="3" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Color" Key="Color"> <HeaderStyle Font-Names="Tahoma" Font-Size="Small" /> <CellStyle Font-Names="Tahoma" Font-Size="X-Small"> </CellStyle> <Header Caption="اللون"> <RowLayoutColumnInfo OriginX="4" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="4" /> </Footer> </igtbl:UltraGridColumn> </Columns> <AddNewRow Visible="NotSet" View="NotSet"> </AddNewRow> </igtbl:UltraGridBand> </Bands> <DisplayLayout Version="4.00" SelectTypeRowDefault="Single" Name="ctl00xUltraWebGrid1" TableLayout="Fixed" StationaryMarginsOutlookGroupBy="True" AutoGenerateColumns="False" RowHeightDefault="32px" RowSelectorsDefault="No" StationaryMargins="Header"><FrameStyle Cursor="Default" BackColor="#EAEAEA" BorderColor="#999999" BorderWidth="3px" BorderStyle="None" Height="424px" Width="100%"></FrameStyle> <Images> <BlankImage AlternateText="Matrix" Url="../Matrix_LOGO.jpg" /> </Images><RowAlternateStyleDefault BackColor="White" Width="30px"></RowAlternateStyleDefault><HeaderStyleDefault BackColor="#00CC66"></HeaderStyleDefault><RowStyleDefault BorderColor="Gray" BorderWidth="1px" BorderStyle="Solid" Height="30px" BackColor="#CCEEFF"><BorderDetails ColorLeft="White" ColorRight="White" StyleLeft="None" StyleRight="None"></BorderDetails></RowStyleDefault><GroupByRowStyleDefault BackColor="#95B9F0" ForeColor="Black"></GroupByRowStyleDefault><SelectedRowStyleDefault BackColor="#0A75F0" ForeColor="White"></SelectedRowStyleDefault><GroupByBox><BandLabelStyle BackColor="#6372D4" ForeColor="White"></BandLabelStyle><Style BackColor="#B5CFF7"></Style><BoxStyle BackColor="#B5CFF7"></BoxStyle></GroupByBox><ActivationObject BorderStyle="Dotted" BorderColor="Black" BorderWidth=""></ActivationObject><FilterOptionsDefault><FilterDropDownStyle CustomRules="overflow:auto;" BackColor="White" BorderColor="Silver" BorderWidth="1px" BorderStyle="Solid" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Width="200px"><Padding Left="2px"></Padding></FilterDropDownStyle><FilterHighlightRowStyle BackColor="#151C55" ForeColor="White"></FilterHighlightRowStyle><FilterOperandDropDownStyle CustomRules="overflow:auto;" BackColor="White" BorderColor="Silver" BorderWidth="1px" BorderStyle="Solid" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px"><Padding Left="2px"></Padding></FilterOperandDropDownStyle></FilterOptionsDefault></DisplayLayout></igtbl:ultrawebgrid>
Hello Sameh,
Would you tell me which Infragistics version are you using (tell me full version number, such as 10.1.20101.1003)? Would you give me the source code of your grid so in order to be able to see what is your scenario?
Lyuba Petrova
I don't want displayed grid like that image ..First : I am choose (ElectricBlue) style for grid ,then I doing height for grid =575 px ,then grid display like image..
