How do I set the filler column styles? I tried the following that didn't work. The default template do not provide any clues.
<Style x:Key="xyz" TargetType="igPrim:FillerColumn">
<Setter Property="Background" Value="{StaticResource HeaderNormalBackgroundBrush}"/>
</Style>
If I had empty style as follows, I get a parse error.
What I want to do is assign the same setting as normal column.
Regards
Babu
Reposting with better format:
<UserControl.Resources> <Style x:Key="redStyle" TargetType="ig:CellControl" > <Setter Value="Red" Property="Background" /> </Style> </UserControl.Resources> <Grid x:Name="LayoutRoot" Background="White"> <ig:XamWebGrid x:Name="grid"> <ig:XamWebGrid.FillerColumnSettings > <ig:FillerColumnSettings Style="{StaticResource redStyle}"/> </ig:XamWebGrid.FillerColumnSettings> </ig:XamWebGrid> </Grid>
You should be targetting a CellControl (which is what fills up the FillerColumn's cell).
="ig:CellControl" >
="Background" />
="White">
="grid">
