275
Summary Row refresh
I have a class with the three property members.  Amount, Frequency, and a calculated field of  MonthlyTotal (Amount * Frequency).  My grid is bound to this object.  I have a summaryRow for the monthlyTotal column.  The summary row correctly shows my sum.
If I change the Amount in the grid on the fly, the MonthlyTotal gets updated, but the summary row doesn't unless I 'refresh' it (i.e. I sort by that column).  Ideas on what I might be missing? Do i have do something to manually force a summary row update?
  • 332
    I also need to refresh the summary row at run time as the user change some data in grid. I found the workaround to refresh the summary row.
    private void
    RefreshSummary(string columnKey) {
    Infragistics.
    SummaryDefinition
    summary =
    from Infragistics.SummaryDefinition
    sum
    in
    _baseGrid.GetXamGrid().SummaryRowSettings.SummaryDefinitionCollection
    where sum.ColumnKey ==
    columnKey
    select
    sum).First();
    summary.SummaryOperand.IsApplied =
    false
    TextColumn quantity = _baseGrid.GetXamGrid().Columns[columnKey] as TextColumn
    Infragistics.
    SummaryOperandBase
    sumOperand =
    from Infragistics.SummaryOperandBase sum in
    quantity.SummaryColumnSettings.SummaryOperands
    where sum.LinqSummaryOperator == Infragistics.LinqSummaryOperator
    .Sum
    select
    sum).First();
    sumOperand.IsApplied =
    true
  • 6475
    Verified Answer
    The summary values are not automatically updated in your case due to performance reasons. You'll need to update the values manually by calling grid.InvalidateData() method.
    Hope that helps,
