There is an issue with the Tools Showing on QAT and Customize QAT menu. (10.1 SR)
If you change a tool's caption at runtime, the link shown on the Customize QAT menu is not refreshed...
Is there any quickfix or workaround for this issue?
Thanx in advance
Michael
Hi Michael,
I was able to reproduce your issue but I couldn't find an easy way to workaround it.
However, there are strict guidelines from Microsoft about how a Ribbon control should work. One of the requirements is that the text labels for the tools on the ribbon must not change.
Hi Georgi.
I will change the behavior and follow the guidelines.
Thank you
