40
xamWebTree and xamWebComboEditor
Is there any example to use xamWebTree with xamWebComboEditor ?
I try to put XamWebComboEditor (autocomplete without popup) into a node of xamWebTree . After set ItemSource within XamWebComboEditor's Loaded function. I can't type into XamWebComboEditor (exist in node of xamWebTree)
Please tell me the solution for this situation.
Thanks.
  • 6759
    Hello dotri84,
    I managed to build a scenario like the one you've described and it is working as expected. Here is the xaml I used :
    <ig:XamTree x:Name="MyTree">
    <ig:XamTree.HierarchicalItemTemplate>
    <ig:HierarchicalDataTemplate ItemsSource="{Binding Products}">
    <DataTemplate>
    <TextBlock Text="{Binding CategoryName}" />
    </DataTemplate>
    <ig:HierarchicalDataTemplate.ItemTemplate>
    <DataTemplate>
    <StackPanel Orientation="Horizontal">
    <TextBlock Text="{Binding ProductName}" />
    <ig:XamComboEditor Width="200"
                        AutoComplete="True"
                        EmptyText="Choose Category"
                        IsEditable="True"
                        DisplayMemberPath="CategoryName"
                        Margin="15,0,0,0"
                        Loaded="XamComboEditor_Loaded"
                        OpenDropDownOnTyping="False"
                        MaxDropDownHeight="0" />
    </StackPanel>
    </DataTemplate>
    </ig:HierarchicalDataTemplate.ItemTemplate>
    </ig:HierarchicalDataTemplate>
    </ig:XamTree.HierarchicalItemTemplate>
    </ig:XamTree>
    If this is not your case please a sample or more detailed description of the issue.
