To be able to resize the OutlookBar (but no minimize), set the width properties on for the parent grid column:
<ColumnDefinition Width="250" MinWidth="40" MaxWidth="400" />
And on the OutlookBar set:
AllowMinimized="False"
To allow the OutlookBar to be minimized (but no resize), set the width property on the parent grid column to:
<ColumnDefinition Width="Auto" />
<igOB:XamWebOutlookBar x:Name="outlookBar1" MinimizedWidth="35" AllowMinimized="True" Style="{StaticResource XamWebOutlookBarStyle1}" GroupContainerStyle="{StaticResource OutlookBarGroupStyle1}" VerticalAlignment="Stretch" HorizontalAlignment="Stretch">
But when I try to combine the two approaches, strange things happen. When I resize the column and then minimize the OutlookBar, the minimized bar is no longer on the left and the first column is wider than the panel.
Is there any way to combine the two so that I can resize the OutlookBar between a minimum and maximum width but also minimize the OutlookBar?
Solution worked great. The only additions were 1) to disable the splitter when the OutlookBar was minimized and 2) to stored the resized column width so that when the OutlookBar was opened it returned to the proper size.
I'm just checking if this solution works for you and if you have any additional questions.
Hi,You have to restore the width of column because the grid splitter changes it.<Grid.ColumnDefinitions> <ColumnDefinition Width="*" MinWidth="50" x:Name="col1"/> <ColumnDefinition Width="Auto"/> <ColumnDefinition Width="*"/></Grid.ColumnDefinitions><ig:XamWebOutlookBar x:Name="outlookBar" GroupsSource="123" NavigationPaneMinimized="outlookBar_NavigationPaneMinimized"/><my:GridSplitter x:Name="splitter" Grid.Column="1" HorizontalAlignment="Left"/>
void outlookBar_NavigationPaneMinimized(object sender, EventArgs e){ col1.Width = new GridLength();}Regards,Marin
