Hi
How can I change the header, cell hover style of column header etc? In general those resources that are not derived from TemplateBinding.
Regards
Babu
Unfortunately, the grid is a part of a framework that is designed to implement common company standards. We believe that a developer concentrates on business logic rather than rudimentary that has same look and feel over all in-house applications.
To be clear, the grid is broken into lots of different styles.
So in this case, you'd be modifying just the HeaderCellControl, which has no where near 3000 lines of xaml.
-SteveZ
The Blend approch is okey for relatively small control like the outlookbar. But for Grid that has roughly 3000 Xaml lines, it is entirely an other matter. I guess for now, I don't have any other choice.
There is not specific Hover Brush property.
Thats controlled via VisualStates in the ControlTemplate of the HeaderCellControl.
If you have Blend there is a help article that explains how to modify the ControlTemplate of a control:
http://help.infragistics.com/NetAdvantage/Silverlight/2009.1/CLR3.5/?page=SL_DesignersGuide_Editing_Style_Properties_Using_Expression_Blend.html
Hope this helps clarify things,
This sets the normal style and not hover style. I use the following:
<igGrid:XamWebGrid ... HeaderStyle="{StaticResource MyHeaderStyle}" ...
Where MyHeaderStyle is defined resource as follows:
<Style x:Key="MyHeaderStyle" TargetType="igPrim:HeaderCellControl">
<Setter Property="Background" Value="Red"/>
</Style>
This no doubt changes the appearance. But, when I hover over the header,. I wish to retain the red background color.
